It is currently Thu Jul 17, 2025 9:48 pm
PostPosted: Wed Apr 29, 2015 1:24 pm
Last Name: Sollod
I'm building my first slothead, a 000 12 fret (have built 10 so far). The stew mac plan shows a 14 degree angle of the headstock, but I have seen a post that indicates that 12 degrees is the angle... Should I go with 14 degrees? ...any comments or suggestions?
www.swiftcreekguitars.com
PostPosted: Wed Apr 29, 2015 1:46 pm
The 1st quality replacement slotted necks I get from Martin are exactly 15 degrees.
I doubt a degree one way or another really matters. As long as the head-stock slants back enough so there is a good contact as the strings cross over the nut.
Ken Cierp
PostPosted: Thu Apr 30, 2015 1:58 am
First name: Heath
Last Name: Blair
City: Visalia
I believe the slot head I built was around 10 or 12 degrees. I think the idea is that you can go a bit flatter with a slot head because the path the strings take to the tuner shaft is steeper. If you draw it out on paper, you can see the break angle over the nut. I'm sure those more experienced will weigh in.
sweat the small stuff.
PostPosted: Thu Apr 30, 2015 7:07 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I use 11-12 degrees for steels & classicals
15 for solid head steel
17-18 for peghead Flamencos.
Mike Collins
PostPosted: Thu Apr 30, 2015 7:50 am
I use 15 degrees for slothead steels but only because I am jigged up for that angle for everything else. It works but seems a little excessive. Pretty high break angle over the nut. I actually like 11-12 degrees better as mentioned.
Mike, do you think the nut break angle has anything to do with the way the strings feel. Higher angle=maybe a little greater feel of stiffness?
PostPosted: Thu Apr 30, 2015 8:01 am
Last Name: Collins
City: Argyle
State: New York
Yes!
For sure on steels.
Gauge of strings/scale length also come into the equation.
mike
Mike Collins
PostPosted: Thu Apr 30, 2015 11:48 am
Thanks Mike. I had that feeling. I need to get off my lazy butt and jig up for the smaller angle.
PostPosted: Thu Apr 30, 2015 3:44 pm
I don't see how the strings would be any stiffer based on the angle. Once set up to pitche they are going to be X kg's of pull regardless right? Unless the thinking is that the larger angle will sort of ramp off the edge of the nut as it breaks over it? But still if the nut is set up proper then it shouldn't matter. Just thinking out loud here.
PostPosted: Thu Apr 30, 2015 5:35 pm
State: ON
I use 14 for solid peghead steel-string, and 10 for slotted peghead SS.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Fri May 01, 2015 6:10 am
Mike Collins wrote:
Yes!
For sure on steels.
mike
While there is plenty of math and science to explain why heavier gauge strings and longer scale lengths actually require more fretting pressure. I am at a loss regarding why or how the head-stock angle would make any difference at all.
Ken Cierp
PostPosted: Fri May 01, 2015 12:38 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Martin uses 15 degrees on everything, but the slotted headstock naturally produces more string break angle across the nut. That means that something even less than 13 or 14 degrees should be fine. Certainly, I have seen plenty of classical guitars with a shallow peghead angle.
